584,865 active members*
4,986 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Ballscrews or rack and pinion? What module of rack and pinion is the best?
    Oct 2010
    16
    Lightbulb Ballscrews or rack and pinion? What module of rack and pinion is the best?
    Hello guys , i am building a cnc router, my Y-axis travel gonna be 2600mm. First i decided to use a ballscrews RM2505 but now i am scared that my travel is too long and my ballscrews can cause vibrations on such a long distance. What is ur recommendation should i go with rack and pinion and what module ? Is a rotating ball nut rational to use in this case? Thanks in advance !
    Jan 2007
    1795
    Re: Ballscrews or rack and pinion? What module of rack and pinion is the best?
    the 5 mm lead too little, with 10 mm lead you can reach 300 ipm safely..
    there are larger diameter, and larger lead screws..
    to achieving a decent speed screws might too expenses..
    however screws are keeping their backlash better than gears..
    2525 L1100MM Ball Screw Dia 25mm Lead 25mm High Lead ballscrew with Ballnut | eBay
    example you can buy 40 mm dia and 40 lead screw.. with 3 and 6 start..
    it means with a simple stepper with 500 rpm you can reach 20 meter paer min, that is 1000 ipm...
    with 500 rpm this screw wont wip as you think..
    with servo it can be 6 times more.. the only issue is your wallet..
  1. calculatiing pinion size for rack and pinion setup
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 08-06-2015, 11:18 AM
  2. dual pinion rack and pinion anti backlash
    By johngalt47 in forum DIY CNC Router Table Machines
    Last Post: 06-12-2011, 04:04 AM
  3. Rack and Pinion- rack tensioned to pinion?
    By Rees Guitars in forum Linear and Rotary Motion
    Last Post: 05-09-2011, 06:05 PM
  4. module 2 rack and pinion
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 03-05-2008, 02:25 PM
  5. Ballscrews or Rack and Pinion?
    By freak_brain in forum Linear and Rotary Motion
    Last Post: 08-26-2005, 10:32 AM
