585,741 active members*
4,992 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Part drawing blank in Mach
Results 1 to 9 of 9
    Aug 2014
    4
    A friend of mine made a part drawing for me in Autocad for a motorcycle gas tank base.
    He sent me the file in a dwg format. I opened it up in illustrator and saved it as an ai file then opened it in Inkscape
    so that I could fill the inside area black. I then saved it as an .svg file and opened it in sheetcam and created a .tap file.
    When I import it to Mach, it comes up blank.
    Anyone know what I'm doing wrong? I'm new to this and any help would be appreciated.
    I've attached the part drawing that I brought into sheetcam if that helps.
    Thanks kindly!
    Attached Files Attached Files
    Oct 2010
    156
    Re: Part drawing blank in Mach
    I can open your dxf in Qcad and in Sheetcam. It may need a little work depending on how you cut it, but if you show green cut paths in Sheetcam, you should see something in Mach.
    HTH
    Paul
    Aug 2014
    4
    Nothing shows up at all in Mach. Just the crosshairs.
    Oct 2010
    156
    Do you see green lines in Sheetcam representing the cut paths after adding an operation? Can you post some or all of the tap file here?
    Apr 2015
    6
    Import your friend's dwg file.
    Somewhere along the way your dxf got scrambled...
    Aug 2014
    4
    I managed to remedy the problem. I still don't know what happened but I exported the drawing as a bitmap in Inkscape, then converted back to a vector.
    I created a tap file again and this time it showed up in Mach
    I don't know why it works now but it does...go figger
    Thanks guys
    Oct 2010
    156
    Good deal.... Much fun, isn't it.
    Aug 2014
    4
    I'm not sure I'd call it fun... more like frustration :tired:
    Oct 2010
    156
    Exactly...
  1. Cnc part larger than cad drawing
    By Raf-1200 in forum Uncategorised CAD Discussion
    Last Post: 12-24-2013, 02:25 PM
  2. Replies: 6
    Last Post: 11-19-2013, 05:53 PM
  3. 2d Tabs on contour to hold part in blank
    By metalworkz in forum Dolphin CAD/CAM
    Last Post: 05-29-2013, 11:22 AM
  4. converting imported part drawing to mold drawing
    By msomerville in forum BobCad-Cam
    Last Post: 08-29-2008, 12:56 PM
  5. Is making a part as easy as drawing it in 3d?
    By randyf1965 in forum Commercial CNC Wood Routers
    Last Post: 04-05-2006, 01:23 PM
