585,741 active members*
5,228 visitors online*
    Oct 2009
    75
    Milling a Part on the 4th Axis
    I am doing 4th-axis milling for the first time (noob alert, and I have only been milling on 3-axis for a year) and I ran into a problem with how to secure the workpiece.
    The workpiece is 1.50" OD and 0.75" in length.
    Initially I had thought that 1/4" all-thread going through the center would secure it if I place hex nuts on each end.
    I was wrong. The bit (1/4" end mill) would sometimes rotate the workpiece when it was milling at the edges.
    I now plan to have an integral rod and flange to screw into the workpiece to secure it.
    Are there other ways to do this?
    Greg
    Feb 2007
    4553
    Re: Milling a Part on the 4th Axis
    A machinable expandable collet or a expanding arbor may solve your dilemma.
    5C16CDIA
    Breakheart Tool Company Products, 8 pc expanding arbor set, 3 pc expanding arbor set, 4 pc expanding arbor set, 5C Collet Stop Set, 5C Expanding Arbors
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Oct 2009
    75
    Interesting. Those are something I haven't seen before. I'm checking them out. Thanks.
    Greg
  1. Replies: 10
    Last Post: 05-15-2012, 04:52 AM
  2. 4th axis milling on my Tormach PCNC 770 part 2
    By 05kevin in forum Tormach Personal CNC Mill
    Last Post: 04-12-2012, 07:33 PM
  3. Milling both sides of an part
    By chris123 in forum Benchtop Machines
    Last Post: 07-09-2010, 07:21 AM
  4. Part holding and milling 3D part on 2.5D Mill?
    By john_t_h in forum MetalWork Discussion
    Last Post: 03-15-2008, 12:35 PM
  5. Part preparation for CNC milling
    By CarbonMike in forum PTC Pro/Manufacture
    Last Post: 04-14-2006, 01:07 PM
