585,722 active members*
4,417 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Not getting signal through bob
Results 1 to 8 of 8
    Apr 2014
    345
    I started to hook stuff up to my control box and ran across a problem. For some reason I don't get any signals through the breakout board. I did test the parallel port sorta by measuring the voltage to pins 2 3 4 etc by setting them as dir and changing it and measuring with a voltmeter. I was able to detect the + 4.3v vs .1v when I changed the dir. I also tested this through the db25 cable. But I can't get anything through the breakout board. Currently I am using a c10 board just to get everything started. So does anybody have any ideas? Also I'd like to know if anybody knows if it matters if you put +5vdc vs ground into the gecko 320x com.Click image for larger version.
    Feb 2007
    4553
    Re: Not getting signal through bob
    Ianagos,
    Move the com jumper to pins 2-3, that will provide 5 volts to the Gecko "Com" connection.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Apr 2014
    345
    I tried that and was unsuccessful
    Feb 2007
    4553
    Question Re: Not getting signal through bob
    Ianagos,
    Is the X6 jumper set to output?
    See attached image.
    Jeff...
    Apr 2014
    345
    Yes it is. I'm wondering what it is because I'm measuring 3 volts at the terminal that goes to the gecko. That doesn't change at all but this is only when com is set to +5vdc when it's set to ground this does not occur. This also only happens to the lines connected to the gecko drives. The next thing I will try is a new computer and also isolating the bob from the case.
    Attachment 276914Attachment 276916
    Feb 2007
    4553
    The G320X uses a universal optoisolator interface polarity circuit. The 'COMMON' terminal (term. 10) may be ground-referenced or 5VDC-referenced. The STEP and DIRECTION inputs are pull-down loads when COMMON is connected to controller GND. The STEP and DIRECTION inputs are pull-up loads when COMMON is connected to controller +5VDC.
    Apr 2014
    345
    I still have not gotten it to work but I I'm wondering if it could be the small capacitor in the corner of the board when I received the board this was damaged ( bent over) and I left it but I saw it again yesterday and I noticed how loose it is. Could that cause any problems?
    Apr 2014
    345
    I think I've found the problem. I'm going to resolder it and see if it works. The problem is there is a little capacitor that was not soldered on one leg. I might as well have bought a cheap Chinese bob. ( maybe this is Chinese?) but crap like this irritates me.
    Edit: I tried it and nothing
  1. 1.6V-3.0V random signal voltage parallel signal from output – Any advice?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 11-12-2009, 11:36 AM
  2. DR SIGNAL OFF
    By mustafaguler in forum Fanuc
    Last Post: 02-22-2008, 07:46 AM
  3. DR SIGNAL OFF
    Last Post: 02-16-2008, 05:26 AM
