585,888 active members*
4,045 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > Reducing direct Line powered 120vac supply from 170 to 150 vdc
Results 1 to 1 of 1
    Feb 2007
    966
    I get a lot of people who want to run their servo motors directly from line voltage without a transformer.
    Here is a way to reduce the voltage output from the direct 169 VDC that you would get if you directly rectified the 120 (120 x 1.141)= 169 Vdc
    Using the secondary of a 12 volt (or greater) transformer out of phase with the 120 volts, it will subtract 12vac volts and give 108 VAC (just as you would get 132 vac (120+12) if it was in phase )
    You can also add a In-rush current device to the 120v input to help reduce surge current when power is first applied such as this one
    Digikey part # 570-1062-ND
    Larry K
  1. High Powered Green Line Laser Alignment
    By bosummer in forum Laser Hardware
    Last Post: 03-12-2015, 05:30 AM
  2. 120vac Vs 240vac on Imported power Supplies.
    By Al_The_Man in forum CNC Machine Related Electronics
    Last Post: 02-02-2015, 04:50 AM
  3. Replies: 2
    Last Post: 12-01-2013, 06:55 PM
  4. C11g Powered from computer power supply
    By adbradley in forum Automation Technology Products
    Last Post: 08-14-2009, 09:36 PM
  5. +5v supply, direct from PC's PS?
    By Zumba in forum Gecko Drives
    Last Post: 04-07-2006, 06:49 AM
