Hi, I have a problem with the spindle drive unit on my LB15. The other day when I started it up there was an unusual noise comming from the spindle & the speed seemed to vary up & down. I stopped it & turned the spindle over by hand...all felt good. I then tried it in reverse (M04) & it ran nice & quiet. I let run for a while before tying M03 again, this time an alarm came up on the screen: 201-4 Alarm A Servo AMP Z AXIS 4802A6 followed by: 110 - Alarm A SDU.
I was able to clear these by turnng the control off & then back on. I have the maintenance log for this machine & found an entry back in 1987 with exactly the same symptoms & alarms. They replaced the regenerative fuse (F5 top LH corner of control unit) & seemed to have solved the problem. There are two fuses located there so I checked them both with a multimeter & they seem ok.
I then pulled the drive belts off the sipndle motor & ran it, the noise is gone but:
M04 fine at all speeds in both M41 & M42.
When in M41 M03, the spindle load meter climbs into or close to the red & flickers up & down at around 300RPM
When in M42 M03 it does it around 2500RPM
Oh, forgot to say...it is fitted with the OSP5000L control
What do you guys think is going on?
