I imported the drawing to DCAD from a LibreCAD DXF (R12) output. When I defined the contour in DCAD - it seemed happy enough - it allowed me to define the contour and give it a name. Now in DCAM - I am attempting to select this contour as a 'Goround' function and I keep getting the error
Contour "Outline" contains errors which have been corrected. The maximum gap/overlay error was "1.197739 mm". If possible you should use PartMaster CAD to correct these errors at source. Do you wish to continue? (Yes/No buttons).
I click 'Yes' and... it seems to 'recover' and actually find the outline. How do I find these gaps using DCAD?
Arden
