585,994 active members*
4,600 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > A non typical application, what smaller unit has a "laser indicator"
    Apr 2011
    I work on custom projects with fabric and velcro (for military patches) and some of the shapes are getting more complex and cutting them with a laser would simplify the process.
    They start as squares with the velcro sewn onto the fabric and then I was hoping there was a smaller Laser cutter that has an "Indicator" or outline where I can align the patch into the correct alignment before hitting "go" to cut it out.
    The max size of patches would be 5"x5" if that matters but of course if its a larger machine I can find more mischief for it to do. I just have no direction in where to start my searches for a unit, I have seen the K40 but I was not sure if it has the capacity to display an outline of work area. Unfortunately I have no one to coach me on this except for you guys, so I thank ya in advance!
    -Rick
    Sep 2014
    128
    Re: A non typical application, what smaller unit has a "laser indicator"
    what you're looking for is a "jig".. ask any mill operator
    Feb 2009
    6028
    Look for one that has a spotting laser. Align to a corner and set your zero. Then hit go.
    Aug 2009
    655
    You'll figure out a way to make it work with any machine, it's not a difficult set up. The laser pointers are sort of junk anyhow. I would cut a cardboard piece out that was taped to the table and voila, you have a jig.
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
  1. "Face milling" with end mills (workpiece is smaller than end mill dia.)
    By hav0c in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 12-24-2014, 02:13 AM
  2. Replies: 0
    Last Post: 11-10-2014, 04:26 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. Smaller CNC ~18"X18" XY with more than 5" Z travel?
    By SkyG in forum Commercial CNC Wood Routers
    Last Post: 12-18-2007, 07:57 PM
  5. Your typical "should I get it thread"
    By july_favre in forum Shopmaster/Shoptask
    Last Post: 03-19-2004, 05:29 PM
