584,833 active members*
5,685 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Estop pushed---green..... Estop pulled out---red fault light
Results 1 to 15 of 15
    Nov 2006
    14
    I am a super-newbie at CNC. I turned on the power of my G540 and the light was green and my estop was pushed in. When I turned the estop to pop it out, the red fault light comes on. I push it back in, it turns green again. I have no steppers connected, the printer cable is plugged in, and Mach3 is open. I don't have pins 10 and 12 jumped because I was told that if your estop is hooked up you don't do that. I'm not very knowledgeable of wiring so if someone has any insight to this it would be greatly appreciated. Thank you in advance.
    Adam
    24216
    Re: Estop pushed---green..... Estop pulled out---red fault light
    Sounds like a wrong contact on the E-stop, N.O. instead of N.C.?
    Al.
    Albert E.
    Jan 2013
    630
    Yep...
    Nov 2006
    14
    O.K. So do I have both estop leads hooked to the same pole? Please forgive my ignorance. I'm more of a mechanical guy than electrical. I not wired that way........Pun intended.
    Adam
    24216
    In some cases the E-stop P.B. has a normally closed AND a normally open contact, if yours has this ensure you use the N.C. for the e-stop.
    Otherwise if just a single switch section, it could be N.O. fitted instead of NC.
    Al.
    Albert E.
    Sep 2009
    1856
    as per the G540 pic for wiring pin 10 to estop other wire back to common or -
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Nov 2006
    14
    Al.
    Unfortunately, none of the contacts on the button are labeled. It's one of those el cheapo Chinese made estops that has one green and one orange side. I have a name brand one coming in the mail soon.
    Adam
    Sep 2009
    1856
    that don't mater if it don't work one way turn it around it should have only 2 or 3 pins signal, common and or a power supply if it has a light in it
    [SIGPIC][/SIGPIC]
    24216
    If it is the Telemecanique type knock off and fitted with dual contacts, then the green contact is the N.O. and red (orange) is the N.C. side.
    e.g. ebay 161687042366
    Al.
    Albert E.
    Nov 2006
    14
    I'm still having trouble with this. I've got pins 10 and 12 wired to the estop (NC side) another wire going from pin 12 to common, and a wire going from pin 11 to V+. It is still going fault when I push the estop in. And that is with my new Allen-Bradley #800E-3D0 estop. I'm at a loss. I do appreciate everyone's help though.
    Adam
    Sep 2009
    1856
    so you have a wire running from pin 10 to estop and a wire running from estop to pin 12 (common) and pin 12 is common for everything and yes pin 11 goes to v+ that`s all correct.
    does the machine run when estop not pushed in
    now do you have the charge pump connected to any thing, if not is it turned off.
    if its connected it should be on and set in M3 if not turn it off.
    what do you have the estop set to in M3 green tick ( active low) or red tick (active high)
    [SIGPIC][/SIGPIC]
    Nov 2006
    14
    Quote Originally Posted by daniellyall View Post
    At this point, I don't have any motors hooked up. I get the fault when I push the estop in. I haven't set anythinmg in Mach3 yet. But I did install the G540 .xml file into the directory. I spoke to Mariss @ Gecko about a week ago and he walked me through the wire colors on my steppers, and he told me to leave my charge pump (I've read a little on charge pumps but I'm still not sure what that does) off for now while I'm testing. I haven't set my parallel to EPP yet in the BIOS. Could it be that? Thanks for that but I haven't made it to active highs and lows yet. That's still Greek to me.I'm still really starting from scratch here. I should have just bought my 540 all assembled and it would have been one less headache. Thanks again.
    Adam
    Sep 2009
    1856
    you should get a fault when you push it in as you would push it in to use ESTOP. if it green when out and red when in its working set up M3 you may not need to set EPP in Bios.
    when you start M3 enable port one the default address should be correct (0x378) then set estop pin as port 1, pin 10 tick enable go out of ports and pins hit the estop button if it goes back into estop mode go back to ports and pins and tick active low.
    see the two pick attached
    [SIGPIC][/SIGPIC]
    Nov 2006
    14
    Ok. So I guess everything with the estop is ok now. Thank you all for all your replies and info. Do I turn my charge pump on whenever I get everything working ok? I just don't know what that is for.
    Adam
    24216
    I always use charge pumps/watchdog timers in the Hardware E-stop string, it is for either detecting programming loaded and running or in the event of a PC failure.
    Al.
    Albert E.
  1. My EStop IN Action
    By msimpson99 in forum DIY CNC Router Table Machines
    Last Post: 09-19-2011, 06:26 AM
  2. Mazatrol t-1 F estop fault
    By pmauldin in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-09-2011, 06:08 PM
  3. estop
    By eloid in forum CNC Machine Related Electronics
    Last Post: 02-16-2009, 03:23 AM
  4. Estop
    By HuFlungDung in forum CamSoft Products
    Last Post: 03-06-2004, 08:24 PM
