Originally Posted by
NC Cams
Geof: the issue I see is the guys come up with some "vaporware" speed at which they want to move the axis, irrespective of whether or not you can cut the material at that rate.
Perhaps with routers or the like you can go zooming right along but when you cut metal you can more oftern than not easily exceed the ability of the cutter with regard to the axis speed that you can jog at.
From what we learned via experiementation, if you want to reduce follower error, SLOW THE FEED RATE DOWN. Both cut accuracy and finish (when cutting metal) are usually improved.
