585,894 active members*
3,993 visitors online*
    Apr 2015
    72
    Mach3 not finding Xbox 360 Controller
    I also posted on the Mach3support site, but thought maybe someone here could have the answer.
    I finished my first CNC build about a month ago. I am using Mach3 v66 fully licensed. All has been working very well.
    I installed and have been using a Microsoft XBox 360 controller, again working very well.
    Today i was moving some stuff around and unplugged my controller.
    Now Mach3 will not recognize it. I have un installed and re installed it a couple of times
    I remember the first time I installed it I had to manually input the Vendor Id and Product ID.
    Now however it will not take that input. I input the ID's but when I go out of the config window it will not retain them. Always shows as "no controller" found.
    Using
    Win7 32
    Mach3 v66
    DirectX v11
    Windows says no problems with the controller
    DXDiag shows no problem with the controller and shows the ID's
    No errors when starting Mach3.
    As a sanity check I installed the XBox controller by shilling. It recognized the controll, but the control is very erratic and not usable.
    So, any ideas where to look?
    Re: Mach3 not finding Xbox 360 Controller
    I am having the same problem. Windows says the controller is working, but Mach3 does not recognize it, and I cannot get Mach3 to retain the VID and PID input. Also, the "None" button is selected in the "Controller" portion of the setup screen and cannot be changed.
    Did you find a solution for this? If so, can you post it?
    Jul 2019
    Quote Originally Posted by jpduffy3 View Post
    Hey There
    Did you find a solution for this problem? I am having the exact same issue
  1. Xbox controller install on Mach3
    By zeeway in forum Mach Software (ArtSoft software)
    Last Post: 01-19-2020, 02:24 AM
  2. Trying an xbox controller on my Mach3 setup... Maybe.
    By voltsandbolts in forum Mach Software (ArtSoft software)
    Last Post: 06-05-2013, 04:20 PM
  3. XBOX 360 Controller
    By riche543 in forum Uncategorised CAD Discussion
    Last Post: 10-26-2011, 08:46 AM
  4. Xbox 360 controller
    By CATCH22 in forum Mach Wizards, Macros, & Addons
    Last Post: 08-24-2008, 12:04 AM
