584,865 active members*
4,913 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > 1/2" Shaft Server / Encoder Problem
    Dec 2005
    141
    I am retrofitting a CNC router table and it has servos that have a 1/2" shaft. I am using the Gecko G320x drivers and i was going to use the CUI AMT102-V Encoders, but they only go to 8mm on the shaft diameter. Does anyone know of another encoder that will allow a 1/2" shaft that will work with the Gecko G320x Drivers?
    Thank
    Mike
    Jun 2013
    1041
    Re: 1/2" Shaft Server / Encoder Problem
    Try us digital. They are not super cheap but they are much better then the amt's anyway.
    Ben
  1. $20 shaft encoder
    By systemslave in forum Mechanical Calculations/Engineering Design
    Last Post: 10-29-2014, 02:57 AM
  2. shaft encoder on sherline lathe under $20
    Last Post: 10-20-2014, 04:28 AM
  3. Weird servo "encoder error" problem.
    By pypes in forum Servo Motors / Drives
    Last Post: 10-06-2013, 05:11 PM
  4. Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft
    By DonW in forum DIY CNC Router Table Machines
    Last Post: 03-17-2008, 09:58 PM
