585,735 active members*
4,699 visitors online*
Results 1 to 9 of 9
Threaded View
    May 2015
    Laser machine disconnects continuously from pc
    Hello Everyone,
    I bought a chinese 50w laser engraver and cutter 3 months back. It got corel laser and laserdrw softwares. corellaser didnt work and I was working with laser draw software. It worked fine before but now while engraving the machine is disconnecting and connecting continuously. Sometimes the machine stops and starts again after 3 seconds. Iam getting the message " Engraving machine is disconnected -
    1. If the machine is not powered, Please power on
    2. If the machine is offline, reconnect it
    3. If prepare to cancel current task, please click [cancel]. Error Id : 0 "
    Iam getting this message only when I set high current for cutting acrylic. It gives a laser firing sound and then it stops cutting but the laser nozzle moves around without cutting. Iam setting current regulation 8 (I think it is mA. Iam not sure as Iam new to CNC and laser cutting) while engraving and while cutting 10 and keep the speed 2mm/s. If I go beyond 10, then the machine disconnects.
    The information which I found on the machine
    mainboard: 6C6879-LASER-M2
    device id: 492B4D1F3D015F57
    Could anyone help me solve this issue ?
  1. Repeat subprogram continuously.
    By sandrewb in forum Fanuc
    Last Post: 04-09-2015, 01:46 PM
  2. Replies: 12
    Last Post: 01-31-2014, 11:01 PM
  3. Replies: 0
    Last Post: 05-17-2012, 02:29 AM
  4. How long can you run a Dremel continuously?
    By Fozzie55 in forum WoodWorking Topics
    Last Post: 07-11-2011, 05:48 PM
  5. Replies: 2
    Last Post: 10-21-2010, 03:24 PM
