585,760 active members*
3,659 visitors online*
    Mar 2015
    178
    Original Bridgeport Branded R8 Collets
    So this is mostly a philosophical question - one that my wife sadly just isn't interested in discussing. Am I alone thinking older, Bridgeport branded R8 collets (especially the ones with the stamped vs etched logos) were somehow better made than the average Lyndex, Royal etc., available today?? For some reason I have this weird obsession of cobbling together an entire set of these in spite of the fact that 99% of the time I only use 3/8", 1/2" and 3/4" sizes. So far I have about 15-20 with including duplicates of common aforementioned sizes. Most are the solid one piece construction type and a few have the staked threaded plug. In addition have a few odd ball Hardinge ones as well. They seem similar to the BP's and possibly more readily available however I don't feel like starting another quest! Believe me I understand that the Royal or Lyndex sets made today are perfectly good probably better than the antiques I seek.
    Honestly I think it's more of a nostalgia thing - wanting objects made in an era of craftsmanship vs today's emphasis on speed, efficiency and low cost to mfg. Consequently, I am always on the look out for these collets in good shape but they rarely pop up.
    Thoughts? Am I the only one?
    Feb 2009
    6028
    Re: Original Bridgeport Branded R8 Collets
    Hardinge makes the best collets, and hardinge and bridgeport are the same company now. Old collets do wear, spring and get the keyway chewed up, but if you can find good ones more power to you.
  1. RF45 (MSC branded) with Ajax retrofit
    By MikeC8 in forum RF-45 Clone Mill
    Last Post: 01-26-2018, 01:31 PM
  2. Original Configuration?
    By SPEEDRE in forum K2CNC
    Last Post: 02-03-2015, 03:37 AM
  3. Original Hoss X2
    By baithog in forum Benchtop Machines
    Last Post: 11-21-2011, 02:17 AM
  4. Alternative to "laser" branded plywood?
    By Solexious in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-28-2010, 01:52 AM
  5. Original Bridgeport CNC Series 1 acceleration?
    By lfleiva in forum Bridgeport / Hardinge Mills
    Last Post: 10-06-2010, 11:27 PM
