Hi,Purchased a CNC machine with a siemens 810d control.
I am a Heidenhain user so am not farmiliar with Siemens but it came with this machine, is there anyone that can help me out please as i am having difficulty in running more than one programme at once.
At the moment i am running single programmes from the installed flash card in the siemens 810d control but need to run more than a single programme.
When i used Heidenhain i just created a programme say call it your name for instance johny in TNC and then inside that programme named the programmes to run ie call programme 1
call programme 2 and so on
So in TNC you would then call programme i named johny and it would run all the programmes named inside that.
If anyone knows the procedure in Siemens 810d to do this it will be greatly appreciated.
Also can someone tell me what to put in for Datum shift in Siemens 810d so i can put this inside the programme that i create to run more than a single programme at a time if i need to cut more than one job on the machine?
Kind Regards
Johny.
