585,741 active members*
4,992 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > fanuc om parameters lost now spindle doesn't work
    May 2015
    Femco kfv 40 1995. Fanuc om control. Lost parameters dead battery. Got all parameters back but now spindle just spins and doesn't stop when reset is pushed. Have to power down to stop. No rpm displayed on screen. have fanuc om manual but doesn't have 6000 series parameters. Can anyone help
    May 2015
    Re: fanuc om parameters lost now spindle doesn't work
    Ok so I got almost everything working. The only issue I have is when orienting the spindle it rotates normally for 1 rotation then slows down drastically for 1/2 rotation then stops at orient position. Any ideas. I have tried changing the orient spindle speeds with no luck. It changes the initial rotation speed but always slows down for the last 1/2 rotation. Please help.
    Dec 2015
    170
    i have same problem with my johnford cnc40 with om control how you will sorted out your problem RESET not working AND NO rpm????
  1. Fanuc OMC - Lost parameters
    By Snowfly in forum Fanuc
    Last Post: 02-04-2014, 06:08 AM
  2. fanuc 3m lost parameters
    By zosos in forum Fanuc
    Last Post: 10-28-2011, 09:16 PM
  3. Replies: 9
    Last Post: 06-15-2010, 12:52 PM
  4. Fanuc O-M lost parameters
    By macperfo in forum Fanuc
    Last Post: 03-27-2009, 12:47 AM
  5. Parameters lost in Fanuc OM
    By wicked_won in forum CNC Machining Centers
    Last Post: 03-27-2008, 10:50 PM
