Red alignment laser line is always specially designed with portable version. It is always workable for accurate red laser line align work in multiple working fields. It is greatly workable for line targeting in textile processing, laser cutting, screen printing, heat transfer machine etc.
This portable red alignment laser always adopts intellectual feedback electric circuit board. While it is being equipped with import 635nm red laser diode, it just assures perfect line generation with high brightness and good direction. Usually its adoption has saved a lot time for users specially spent on primary line adjustment before real alignment work.
When it is used for longer working distance or high brightness line generation work, it will play advantages that are more obvious in operation. Sometimes it is used under sunlight working environments, it is just workable. However, common 650nm red laser cannot achieve. After simple adjustment of red laser line direction adjustment, this advanced alignment laser tool will begin to make stable and reliable line generation in operation.
