Originally Posted by
hrh
Logically if the arm is pushing the tool properly into the waiting pot on the magazine but not sufficiently into the spindle, then I conclude that the spindle height is not correct.
Alternatively there is a timing issue with the draw-bar cylinder and the arm movement. You may have to adjust the "timing drum" (small cylinder with slots milled into the surface)
If parameter related, the PC parameters (which are machine tool specific) may need some tweeking. Adjusting a timer to move the arm after the clamping is confirmed.
