585,926 active members*
3,939 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > SYSTEM FAIL 8004d Realtime Timeout
    Oct 2011
    23
    Exclamation SYSTEM FAIL 8004d Realtime Timeout
    Hi guys
    I have a problem with the machine CINCINNATI MILACRON 1000 ACRAMATIC 2100
    The problem is: SYSTEM FAIL 8004d Realtime Timeout
    The error appears always different:
    Sometimes 2-3 times in one day
    Sometimes once every two - three days.
    Does anyone have an idea what the problem or the solution itself.
    Thank you Nicolas
    Nov 2007
    188
    Do you have a ground rod attched to the machine we had this problem with 2 of ours and drove a ground rod next to them and hooked it up and the problem went away
    Re: SYSTEM FAIL 8004d Realtime Timeout
    I fixed the problem by adding a fan on the CPU.
    Dec 2006
    584
    I think you may have a RTC or the work station board battery going bad. This is the first error that comes up before you lose the BIOS or the settings. You should write down all of the BIOS settings and back up your system and the M1Y****.bak file.
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
  1. A2100 Realtime fail
    By slowlearner in forum Cincinnati CNC
    Last Post: 05-17-2018, 05:58 PM
  2. cincinnati arrow 1000 realtime timeout error
    By stuart wiezniak in forum Cincinnati CNC
    Last Post: 04-24-2013, 10:26 PM
  3. Realtime system did not load
    By Makeek in forum LinuxCNC (formerly EMC2)
    Last Post: 04-14-2011, 10:32 AM
  4. Closing in on system fail 58 NEED HELP
    By vebers in forum Cincinnati CNC
    Last Post: 11-12-2010, 11:23 PM
  5. Realtime timeout!
    By matthew6060 in forum Cincinnati CNC
    Last Post: 02-22-2009, 06:33 PM
