585,717 active members*
3,938 visitors online*
IndustryArena Forum > CAM Software > Vectric > Print chipping away during rout
Results 1 to 7 of 7
    May 2015
    I am somewhat of a beginner with the multicam 1000 series router. I am routing out acrylic that has been printed on the reverse side (using a rastek flatbed printer), I have the back side (print side) masked and it is chipping away the print. Any suggestions on how to prevent this? Also, it is scratching the top side of the acrylic...Would you recommend a pre mask on the top side to protect the surface from getting scratched? Most sign shops I have worked at, we would rout the acrylic first, then paint it in a paint booth. I am wondering if I am doing this backwards by printing then routing.
    Jason
    Dec 2014
    103
    Re: Print chipping away during rout
    hi there
    I rout acrylic at work and then it gets printed. the acrylic should have masking on it when you rout it to protect it keep it on as long as you can as for it takes nothing to leave a mark
    Apr 2004
    475
    Premask both sides with paper after printing. Printing side down, upcut spiral carbide bit, that should have 0 chipping. Might work on topside printing too.
    Jan 2007
    1795
    sure that makes more sense..
    after cutting out, if outline is not a rectangle or square, I think you can print outline on another media and that shows where you have to place the cut acrylic fpor printing....
    reynobond or sintra or coroplast works, but acrylic is different..
    May 2015
    Thanks all for the input. All great advice!
    Nov 2015
    Given you've got the CNC potion worked out, having the correct ink set will contribute to chipping also on acrylic. I know this is an older post, but digital UV presses usually struggle with acrylic and corrugated plastic specifically to get good adhesion.
    Sep 2008
    always make sure that you cut into the material, so if your print is on top side, use a down cut bit, if the print is on bottom side use an up cut bit
    but the safest way is to cut first print after - in case of a flatbed printer you can print a key line for positioning your piece
  1. VTL, STAINLESS ,INSERT CHIPPING
    By BOATDUDEGUY in forum Material Machining Solutions
    Last Post: 07-25-2013, 04:07 PM
  2. how to cut both side melamine chipboard without chipping
    By concepto in forum Community Club House
    Last Post: 03-11-2013, 04:52 PM
  3. Engraving Anodized Aluminum: chipping?
    By Frogblender in forum Engraving Machines
    Last Post: 03-17-2010, 06:46 PM
  4. Replies: 3
    Last Post: 01-05-2009, 02:36 PM
  5. Chipping melamine edge during a cut.
    By ynneb in forum Community Club House
    Last Post: 03-17-2005, 03:02 PM
