584,866 active members*
5,249 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Sprocket gcode/cad file creator
Results 1 to 12 of 12
    Feb 2005
    5
    I'm a computer geek who hangs around the machine shop too much and I wrote a small program in response to our need for creating gcode for milling sprockets. In order to visually confirm the results from the desktop I also made it generate a CAD file (dxf). Anyway, I thought it was too neat / useful not to share so I've posted it on my website at http://www.idleamusements.com/sprocketeer.htm. You basically choose the standard chain size ( or enter a custom pitch and roller diameter) and the number of teeth and it generates the gcode and CAD file.
    Download it and give it a spin. If you find any problems or have any suggestions for improvement please let me know via the email address on the page.
    Mike
    Sep 2006
    7
    Hi Mike,
    This is just what I need for our High School Robotics competition this January. Unfortunately, the downloaded program doesn't want to work, I keep getting an error about some file thats missing.
    Feb 2005
    5
    I've created an installation package which should include all of the files that you'll need. It is now available for download at http://www.idleamusements.com/sprocketeer.htm . If you have any problems or have any suggestions let me know.
    I also wouldn't mind some pictures of the final result for my webpage if you find this little program handy.
    Enjoy,
    Mike
    Sep 2006
    7
    Mike, I successfully downloaded and installed the program. Pretty neat. The computer at school where our shop is had some trouble installing the program, but I had no problem at home. I'm going to take the g code file to the school tomorrow and see if I can't cut a sprocket.
    I've been wanting to cut sprockets for about 5 years now. I even made a servo driven gear/sprocket hobbing attachment for our manual mill this year. This should be a lot faster and easier!
    Thanks!
    Alan
    Sep 2006
    7
    Hi Mike,
    I ran your program and generated code for a 18 tooth 35 pitch sprocket. We haven't actually cut it yet, but I loaded it into our Tormach Mill stuck a pen in it and it traced the outline of the sprocket. We will probably cut the sprocket this weekend when I get the coolant pump going. One thing I noticed is that the tooth profile is a bit taller and sharper than an ansi standard sprocket. I don't think this is a problem, but it is a bit different.
    Feb 2005
    5
    I left the teeth as pointed as they could be. It seems that the final point cut of the sprocket teeth is something of a personal preference so I left it up to the machinist to make that final cut. Basically add a final circle event with a center of 0,0 and the diameter of your desired final profile.
    If anyone can find a good standard or rule of thumb for that final trim then I'll make it cut that path from the start, or add that final event at the end.
    Mike
    thats a neat lil program ,
    the program is great as it is bud
    it would be easy for a guy to throw in a circular pass to knock off the excess ,if desired
    Mar 2004
    261
    Very nice routine. Fills a niche. Thats' what software is all about.
    Jul 2010
    Thanks Mike, it's small programs like this one that made the Internet a geat place. It was exactly what I was looking for.
    Mar 2008
    195
    Sprocketeer is an awesome program. I made a custom sprocket last week for a guy who does trick riding on a sports bike and needed a different ratio.
    plasmacut from .025 steel and then powdercoated
    Apr 2018
    Re: Sprocket gcode/cad file creator
    Hi Mike
    I used your program to make 34 teeth sprocket for 530 chain. The teeth came out too thick and too tall and I had to do a lot of grinding work with dremel tool to make it workable. Did I have any mistake?
    Apr 2021
    Hi Mike. How about adding Narrow-Wide teeth as an option? Br Finn
  1. Stereolithography file to GCode
    By rweatherly in forum Coding
    Last Post: 03-22-2018, 04:05 AM
  2. Bed Level Gcode Creator V0.1 Beta
    By CLaNZeR in forum OpenSource Software
    Last Post: 07-18-2009, 08:07 PM
  3. Need gcode or dxf file for drilling UHU PCB
    By visky in forum UHU Servo Controllers
    Last Post: 10-07-2008, 08:45 PM
  4. Is there any way to add notes to a gcode file?
    By Anokiernan in forum G-Code Programing
    Last Post: 02-22-2008, 04:11 AM
  5. Can Someone Covert File To Gcode?
    By bcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-27-2007, 03:16 AM
