Usually straight line and cross lines are very in need in embroidery work. As a result, alignment laser tool is just in need to set up with embroidery machine. Cross line laser alignment is just able to project exact 90 degrees perpendicular lines on processing garment, thus it can greatly improve line targeting accuracy and line straightness greatly.
On consideration of high accuracy cross line align, usually 532nm green laser alignment is the first choice for embroidery operation. After easy mounting on required working surfaces, both vertical and horizontal green laser lines are very straight, bright and clearly visible.
This superiority has just assured 100% success rate of every embroidery work made by embroidery machine. At the same time, the alignment laser cross line also saves a lot of time for cross line calibration work. It is just the correct tool which has made embroidery more simple and more easily.
