585,992 active members*
6,011 visitors online*
    May 2013
    Gildemeister CTX400 Eltro Pilot Keypad
    Hello all,
    I recently installed an EPL 2.2 control unit repaired and refurbished by DMG Mori into a CTX 400 lathe. I have a good boot up with all parameters initialised.
    When prompted to press operating mode key I have no response from the keypad. I believe i have a good connection back to the control and thought maybe the board behind the keypad may be faulty. There is signal between the control and keypad as when i start without connection i get "system error". with connection everything boots fine but i have no response from keys.
    Id appreciate any help with this.
    Thank you.
    Paul
    May 2013
    Re: Gildemeister CTX400 Eltro Pilot Keypad
    Problem solved. Sent Keypad FTE board to an automation company for test/repair.
    Control now working however some parameters still incorrect for the machine.
    Apr 2009
    18
    Quote Originally Posted by flynno83 View Post
    Hello all,
    Thank you.
    Paul
    Hi Paul
    Are you have ctx400 with ELP2 gieldmaiester parameter
    My email [email protected] if possible you please send me.
    Best regards
    Fatehi
  1. Gildemeister CTX400 with heidenhain pilot
    By robkavitch in forum Post Processors for MC
    Last Post: 10-26-2013, 03:04 PM
  2. Any Gildemeister lathe operators out there? I'm looking for opinions on 5 axis CTX400
    By MadMax in forum Uncategorised MetalWorking Machines
    Last Post: 03-08-2013, 07:36 PM
  3. mitsubishi keypad
    By ikennedy in forum Want To Buy...Need help!
    Last Post: 08-01-2012, 06:09 AM
  4. Keypad/Touchscreen
    By mmckell in forum Cincinnati CNC
    Last Post: 02-07-2012, 07:05 PM
  5. Inverter Keypad Help
    By JacquesLeDick in forum Excitech routers
    Last Post: 12-05-2011, 02:41 AM
