Hello All
I am working on a series 5 Fanuc, with Fanuc model 5 and 10 servos.I have checked the +5V precision voltage on the power supply and adjusted it to +5.026V or so,it was +5.126V. The +6V and-6V reference voltages are 6.148 and 6.030 respectively. Do these need adjusting and if so is the RV3 pot the correct method? I have moved it back and forth and no change. Also is there any other voltage checks/adjustments I could complete to eliminate a run/drive away problem? Regards Craig
