585,676 active members*
4,680 visitors online*
Results 1 to 19 of 19
    May 2007
    15
    Amada Vipros 357, Fanuc 04PC
    We have an Amada Pega357 with Fanuc 04PC control and We have error msg.:
    " E 44 HDLC response time out - error "
    Can Anny help?
    May 2007
    15
    Re: Amada Vipros 357, Fanuc 04PC
    I get this on start up:
    "bootstrap file A: cannot find loader"
    "bootstrap file B: cannot find loader"
    "bootstrap file C: cannot find loader"
    "bootstrap file D: cannot find loader"
    "bootstrap file E: cannot find loader"
    "bootstrap file F: cannot find loader"
    "bootstrap file l: cannot find loader"
    Feb 2015
    161
    Press "MMC/CNC" button.
    What happens?
    May 2007
    15
    When I press "MMC/CNC" button, on screen is:
    0166-10
    NOT READY
    servo: 9046-04
    On Master printed board (A20B-2000-0180-06B) lighting L2 red led...
    Feb 2015
    161
    Press the Message key to see what alarm is displayed. Could be a servo alarm, something wrong with MMC circuit, or a problem with Emergency Stop releasing.
    May 2007
    15
    Where should be connected this end of cable,
    Attachment 314476
    Other end is connected here:
    Attachment 314478
    Other pictures:
    Attachment 314480
    Attachment 314482
    Attachment 314484
    Feb 2015
    161
    I cannot view those attachments. Can you try to load them again?
    Thank you.
    Oct 2005
    89
    hi Jovanov,
    did the machine went into power down situation ?? by any chance...?
    it looks like your FANUC boot loaders are not loading properly. Check the I/O board connections.
    By the way the attachments are not opening. pls Re-post them.
    thanks.
    May 2007
    15
    Attachment 314508
    Attachment 314510
    May 2007
    15
    May 2007
    15
    Second picture is A16B-1211-0900-13B, connector is M24
    Feb 2015
    161
    M24 should go to M60 on a IO board
    May 2007
    15
    "bootstrap drive A: cannot find loader"
    "bootstrap drive B: cannot find loader"
    "bootstrap drive C: cannot find loader"
    "bootstrap drive D: cannot find loader"
    "bootstrap drive E: cannot find loader"
    "bootstrap drive F: cannot find loader"
    "bootstrap drive l: Loading CCPM.SYS
    This is video of start up:
    https://youtu.be/cGqjGtWyKW4
    Feb 2015
    161
    That's a good step. Has this machine been off for a while? Push the MMC button again. Same NOT READY screen? It just booted up on the MMC side. There is a parameter to switch which side is booted on startup.
    13 bit 4
    0=CNC screen
    1= MMC screen
    Oct 2005
    89
    As i said your machine is not booting properly. Do you have Parameter & DGN backup...?
    if so try flushing the parameters .
    May 2007
    15
    Yes, it was off for a while, I push the MMC button again, Same NOT READY screen... How to change parameters?
    May 2007
    15
    No, I dont have Parameter & DGN backup...
    May 2007
    15
    On which PCB is stored drive A:, B: C: D: E: F: ? - On memory board, or other?
    Oct 2005
    89
    HI
    at least do you have the parameter tapes ( perforated black tapes) with you ? ( usually supplied along with the machine )
    if not then it will be little difficult to restore the machine on your own.
    was this machine working OK with you before ?
    If at all you need I can make a visit to the place to restore your machine.
    let me know. Contact me at [email protected]
  1. Amada pega fanuc 04pc system error
    By cndcnd in forum Fanuc
    Last Post: 10-10-2018, 04:47 PM
  2. AMADA VIPROS 357
    By Am357 in forum DNC Problems and Solutions
    Last Post: 03-16-2016, 12:46 PM
  3. Amada w/Fanuc 04PC ocsillation at stop
    By Mister NCT in forum Fanuc
    Last Post: 06-10-2011, 04:04 PM
