My gecko has no power on ARM+, ARM-
Hi!!!
I really really ned help, and i apreciate if some one can give me a hand..
Yesterdey I have my CNC working O.K. with 3 G320 geckos, today I added an emegency stop to the sistem, and a signal to the parallel port (controled by MACH3).
After that I start to tune my servos (gain & damp) X axis and Y axis pass all the proces sucsesfully, but when I try the Z axis, the servo had no power, Every thing else is right, just the Gecko ARM + and ARM- terms has 0 volts.
If I connect the Z servo to the Y Gecko, works fine.
If I connect any servo to the Z Gecko just don't work!!!
AFTER READING ALL THREADS on this forum. (nuts) (flame2)
I found someone to have a kind of the same problem
http://www.cnczone.com/forums/showthread.php?t=7347
I make 3 connections circuits diagram pictures to show the changes, How was the circuit yesterday, today and the measurements with a multimeter.. (I omited the untouched connections)
Thanks guys In advance
Before you can make it, you need dream it!!!
