OK...I'm stumped! So far my experiences with this machine has been "everything that is there, is there for a reason." I should also say that this is my first machine and I'm still trying to figure everything out.
Well I found a knob behind the head (directly behind where the spindle sits). It's on the big peice of metal that slides the whole head forward and backward. If I look underneath I can see that it is a worm screw. I can also see some large gear above it that moves with it. It turns very easily just by hand as if it's not connected to anything. It is limited in both directions so it won't just turn continuously.
If I were to guess, it's a part that would be used if the head had a y-axis swiveling capability. This machine for sure doesn't have that capability. Even the part that the screw drive is in just has four big bolts holding the head on so it doesn't even seem like a part that could accomodate a swiveling head. I was wondering if it maybe had something to do with removing the spindle. Which BTW is a Kwik Switch 200.
And, not to hijack my own thread...is it possible to use an R8 tool with this system? I looked at the top of the spindle to see if there was a standard draw bar. It appears to be recessed about 8 inches and there is some sort of splined shaft. I'm getting a little sick of trying to find Kwik Switch tool holders...R8's seem to be a dime a dozen.
Anyone?
