High quality laser tube: IPG500W
Untouched following system
Yasukawa servo system
Imported ball screw and linear guide rail driving system
Auto partitioned exhausted system
Industrial chiller
Off-computer control system (Supported files: DXF,PLT,AI)
TechnicalTechnical
Working area:1250mmX2500mm
Dimension:3600X1900mmX1900mm
Positioning accuracy:±0.05mm/m
Positioning speed:20m/min
Weight:2000kg
Power supply:380V±10%/20A
Capability
stainless steel
carbon steel
Galvanized sheet
Speed:
Material
m/min
carbon steel 1mm
8
carbon steel 2mm
4.2
carbon steel 3mm
2.1
carbon steel 4mm
1.2
stainless steel 1mm
7.2
stainless steel 1.5mm
stainless steel 2mm
1.8
galvanized sheet0.8mm
5
galvanized sheet1.2mm
2.6
galvanized sheet1.5mm
1.8
Running cost:
Electricity cost
≤6KW
Laser gas
Not
Assisted gas
Oxygen/Nitrogen/compressed air
The parameters showed are based on the client actual The assisted gas will be used according to the different materials (such as stainless steel and carbon steel). working situation,only for reference!
Attachment 280776
for more news :
skype: wkquiven
[email protected]
quiven from gweike laser
