585,589 active members*
3,613 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > Leadshine ES-DH1208 faults wtih ER020 frequently
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    May 2015
    38
    Re: Leadshine ES-DH1208 faults wtih ER020 frequently
    Hi Ron,
    Thank you for your attention on Leadshine products.
    Err020 means position following error. Our default setting is 1000 pulses in the software. If the error value of encoder feedback exceeds 1000, Err020 will be generated. ER020 frequently, could you please check encoder cable if it's loose(bad connection) or too high acceleration. By the way, what motor model do you use ?I need to check if its Leadshine motor and encoder resolution.
  2. #22
    May 2015
    38
    First of all, I'd like to know what model of new motor you have changed? If you have used Leadshine encoder extension cable ? I think there are some problem with encoder signal transmiting between your new motor and ES-DH1208.
Page 2 of 2 12
  1. MX 4660 from Leadshine
    By malgazz in forum Stepper Motors / Drives
    Last Post: 07-28-2016, 06:40 AM
  2. Multipass Issue wtih Multicam CNC
    By huez in forum Aspire
    Last Post: 03-30-2015, 04:58 AM
  3. XHC wireless USB MPG Pendant WHB04 - Frequently Problem
    By ProxSmart in forum CNC Machine Related Electronics
    Last Post: 05-26-2014, 08:20 AM
  4. New Member needs Help wtih mini lathe ballscrew mod.
    By yakfisherman in forum Mini Lathe
    Last Post: 12-31-2009, 09:22 PM
  5. DC Spindle motor tripps off frequently
    By gowthu in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-06-2008, 02:48 PM
