585,872 active members*
3,518 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > A couple of really annoying problems with SC9
    Oct 2010
    253
    I've been updating to current stable builds and I'm have been having a couple of problems that are annoying as all get-out. These problems have been there since I upgraded to SC9.
    1) invoke 'Save' and every now and then it takes about 5 minutes! ( I'm on a fast machine with lots of memroy ) SC goes into some state where it just waits, there is nothing you can do, until something times out. The file does get saved however. I've had this problem ever since SC7.
    2) Run the post processor, and SC quits once you hit the 'Exit' button. This happens both if I am in the PP window or the PP generator app.
    Anybody have these problems or been able to fix them?
    May 2015
    17
    Re: A couple of really annoying problems with SC9
    I have not experienced either of these problems. Therefore, I suspect that you are having software conflict problems of some kind.
    Jun 2015
    16
    I have the issue you describe even after doing a fresh install of windows8 and installing only sprutcam and MS office. So i think it is in the SW and not your system.
    My version of SW is Version 9(build 1.0 Rev 79194 x64 RL 08/04/2015).
  1. Solidcam is annoying!
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-13-2009, 01:33 PM
  2. My second cnc build. Lots of pictures. A couple of problems.
    By OneAndy in forum DIY CNC Router Table Machines
    Last Post: 01-09-2009, 08:16 PM
  3. Really Annoying Keygrabber Bug, Help?
    By b0gh0s in forum Mach Software (ArtSoft software)
    Last Post: 01-10-2008, 08:51 PM
  4. Couple of EMC2 G-code problems.
    By MagooT in forum Post Processors for MC
    Last Post: 12-26-2007, 06:27 PM
