I am looking for a machine to be a dedicated machine for one part that is 2"x2"x2" and will be done on a 4th axis in large quantity. I am looking at the Brother Speedio S500 or the RoboDrill ECO. Both about the same size. I am happy with both of the Quotes but want input on your machines as I have never ran either. The Brother Speedio will come with a 16K spindle, the RoboDrill is 10K. I don't want to go the 27K rpm spindle as I just don't have faith in the longevity of anything that runs that high of rpm. The Brother guys swear the 16K spindle can run wide open for extended periods of time. I will be looking for high speed look ahead as I do have some surfacing work on the part. Can anyone say one is more ridged than the other? I am cutting aluminum with small end mills so it will not matter on this job but I always want the most solid I can get.
I looked at a Haas DT-1 since I have other Haas and love them. The DT-1 has less pulses/rev encoders and 20mm pitch ball screws witch I do not like. The Brother has 12mm pitch ball screws and 1.2 million pulses/rev encoders. I am sure this is why the Brother and RoboDrill have more than twice the table load capacity over the Haas. Moving more weight with a 20mm pitch is harder and I will run a HA5C 3 spindle indexer on it. Also the Haas needs a 100 amp breaker and the others are like 30 amp so that helps me in the location I am.
Are there any things that you know about the Brother or RoboDrill that make it more attractive? Less Attractive?
thanks in advance
