585,604 active members*
3,312 visitors online*
Results 1 to 6 of 6
    Mar 2011
    68
    Solidcam 2.5D default lead in
    Hello,
    Is there any possibility to change the defaults leads in and lead out for solidcam 2015?
    I always have lead in and lead out arc with different datas, and I want to have none like in old solidcams.
    Please if anybody know to give me the way to change I'l will thanks a lot.
    Greetings,
    Claudiu
    Oct 2013
    153
    Re: Solidcam 2.5D default lead in
    Looks like it's using the default template. To change this go to solidcam setting \ defaults \ templates in the 2.5d column uncheck the boxes if you do not wish to use any template .
    Oct 2013
    153
    the other way is to create a 2.5D operation as you want it to be and save it as a template
    then set this template as a default template . by this way when ever you start a new operation solidcam will
    load your template
ID:	281056 Click image for larger version.
    Mar 2011
    68
    Hello,
    Thanks for answer.
    I tryed to save it, but after saving, there is nothing in settings template when I check profile.
    I found some templates and now I can check the box from settings, but still don't use the template.
    Can you show me how you save it?
    Maby with Team viewer?
    Many thanks.
    Oct 2013
    153
    i have created a video for it . hope its helpful
    https://youtu.be/xTWPy92ShV0
    Mar 2011
    68
    Hello,
    Thanks for answer.
    It works now. I didn't selected any tool, and when I tryed to save, it didn't saved it.
    Thanks again.
    Have a nice day
  1. Lead in Lead Out Corner Types Cut Order and More!
    By aldepoalo in forum BobCad-Cam
    Last Post: 03-09-2015, 11:07 PM
  2. Lead In/Lead Out missing from 2D Contouring
    By kzulonas in forum SprutCAM
    Last Post: 09-12-2013, 08:05 AM
  3. Ramp toolpasth/Lead in-lead out (engage) question
    By MadPickinSkills in forum UG NX
    Last Post: 08-24-2013, 05:35 AM
  4. Replies: 3
    Last Post: 06-25-2013, 04:54 AM
  5. lead in-lead out on surface toolpath
    By Tugiyana in forum Mastercam
    Last Post: 05-07-2007, 11:16 AM
