585,994 active members*
4,692 visitors online*
Results 1 to 6 of 6
    May 2015
    Z70 Abs. Data Error 0001 Z1.
    Hello all.
    We have a M20 Citizen CNC machine, with this alarm,
    Z70 Abs Data Error, 0001 Z1
    Z70 Abs. Data Error, 0001 Z2T1
    Z70 Abs Data Error 0001 Z3.
    This Machine was down for a power supply 220 vac to 24 vdc. we replaced the power supply but this alarm is showing.
    Can you help us?.
    Nov 2014
    26
    Re: Z70 Abs. Data Error 0001 Z1.
    Z70 is a zero return alarm
    Zero return all axis the only one that could be a problem is T1 there is a procedure for this if you need it
    Jul 2019
    53
    Ti zero return
    You have to make the origin of the machine but first you have to do it before t1 turret If you want to get the procedure [email protected]
    May 2019
    7
    Hi . good day . I have a Cincom M20 lathe that has Z70 data error alarm 0004 A, thank you if anyone can help
    Nov 2014
    26
    Z1 axis needs a zero return
    Jul 2019
    53
    Quote Originally Posted by Milad127 View Post
    Hi Brother I hope all is well yes it is necessary to make the origin of the Z axis there is a procedure to do that if you can not send me on my e-mail
  1. error 368 X AXIS : SERIAL DATA ERROR (INT)
    By mattpatt in forum Fadal
    Last Post: 02-24-2023, 02:01 PM
  2. arc data error
    By slowdigits2 in forum G-Code Programing
    Last Post: 11-25-2014, 10:39 AM
  3. Masterwood error code 06.06.0001 and 06.02.0001 ????
    By redwatch in forum CNC Machining Centers
    Last Post: 07-08-2014, 08:07 PM
  4. 0001 E-Stop or PLC Alarm Error
    By mjb268 in forum Maintenance DIY Discussion
    Last Post: 10-25-2012, 03:27 PM
  5. Citizen A32 Z70-0001 Zero position error
    By smellyfeet in forum CNC Swiss Screw Machines
    Last Post: 06-15-2010, 01:20 PM
