585,926 active members*
3,868 visitors online*
    Dec 2013
    17
    Computer suggestions to run Mach 3
    I would like some opinions on purchasing a refurbished computer to run Mach 3 for my cnc conversion of a G0704 mill. There really isn't anything local to purchase, so I am going buy online. There are a lot of Dell OptiPlex systems on sale at Newegg, etc. Any problems with them and issues with any other brands/models? I could get something like the following HP: Refurbished: HP Desktop Computer DC5100 Pentium 4 2.8GHz 2GB DDR2 80GB HDD Windows 7 Home Premium 32-Bit - Newegg.com
    Requirements if using the parallel port for machine control:
    •Desktop PC (Laptops are not supported) with at least one parallel port
    •32-bit version of Windows 2000, Windows XP, Windows Vista, or Windows 7 (64-bit versions will not work)
    •1Ghz CPU
    •512MB RAM
    •Non-integrated Video Card with 32MB RAM(Large G-code files, especially 3D files will require a video card with 512MB RAM or higher
    Feb 2015
    22
    Quote Originally Posted by DJR22013 View Post
    •1Ghz CPU
    •512MB RAM
    Laptops are supported. It'll add to the cost. A uc100 or smoothstepper can communicate with a laptop.
    Those pcs look perfect for a dedicated machine control pc.
    Jun 2015
    943
    Re: Computer suggestions to run Mach 3
    Some Dells have problems if you are running with LPT port. I'm not sure which models though. I encountered timing issues with a Dell a few years back when I was using printer port.
    Or as JSantars adviced you could use a Smoothstepper or UC100 these work with ethernet and USB ports, I have both an both work great.
  1. Computer For Mill, Suggestions?
    By AndrewEvans in forum Controller & Computer Solutions
    Last Post: 05-30-2011, 07:25 AM
  2. need help with mach 3 or computer
    By carminemarcelli in forum Linear and Rotary Motion
    Last Post: 01-31-2010, 12:26 AM
  3. Need suggestions for EMC2 computer
    By marzetti in forum LinuxCNC (formerly EMC2)
    Last Post: 01-04-2010, 04:53 AM
  4. What is computer min req' for MACH 2 and 3?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 04-19-2007, 12:53 AM
  5. VM and Mach on the same computer?
    By Rhodan in forum Visual Mill
    Last Post: 02-21-2007, 10:32 PM
