585,692 active members*
4,993 visitors online*
    Oct 2003
    208
    Ace Converter G-code Question
    ACE CONVERTER DOESN'T PUT LINE NUMBERS IN THE G-CODE IT PRODUCES.
    ANYONE KNOW OF AN EASY WAY TO PUT THEM THERE?
    2139
    Re: Ace Converter G-code Question
    Are you sure? I thought there was an option to do this when converting.... I will get back to you.
    Eric
    I wish it wouldn't crash.
    2139
    Check off "Generate Block Numbers" in the dialogue box when converting.
    Eric
  1. TurboCad 6 vs 10.2 with Ace Converter
    By goodeye in forum Uncategorised CAM Discussion
    Last Post: 11-27-2007, 09:59 PM
  2. parametric programming
    By Karl_T in forum CamSoft Products
    Last Post: 05-24-2005, 08:58 PM
  3. 0,0,0, UCS, and Ace
    By JW Peters in forum Autodesk
    Last Post: 04-12-2005, 01:02 AM
  4. 3phase servo retrofit
    By whiteriver in forum Servo Motors / Drives
    Last Post: 02-07-2005, 04:27 AM
  5. Tool Change
    By WOODKNACK in forum Uncategorised CAM Discussion
    Last Post: 07-13-2003, 03:26 AM
