Hi all, I need to have all uppercase in the comments on a lathe post. Does anyone know if I can force the post to output all uppercase letters?
Should be doing that by default, however if it is the comments like "Machine Setup 1" and Feature names that are the issue then you can simply type them in on the CAM Tree using the "rename" facility, see the attached image
Here is some code that produced
O100 ( FILE SAME TOOL ALL.NC SL25-MC WED. 05/27/2015)
(MACHINE SETUP-1 FACE ROUGH )
(TOOL #999 CCMT )
Hope that helps
Regards
Rob
:rainfro: :rainfro: :rainfro:
Thanks for your reply. No its not doing it by default. I hoped there was a switch or button somewhere in Bob-cad that would do it for me.
By the way I'm using BobCad 27.
