The hammer mill is a machine whose purpose is to crush materials by the collision between the high-speed hammer and materials. It is suitable for milling raw material like tree branch, cotton stalk, corn stalk, wheat straw etc. with size less than 50mm (diameter). After milled, the output size can reach diameter 3-5 mm, then it is suitable for further processing. Hammer mill is widely used in the pretreatment of raw materials in feed pellets production. It is used to pulverize the raw materials into small powders for later smooth pelletizing. Our hammer mills all have the advantages of compact structure and low power consumption. The fundamental theory is simple.
A hammer mill is actually a steel drum consists of a vertical or horizontal rotating shaft or drum on which hammers are mounted. The hammers swing on the ends of the cross freely, or fixed to the central rotor. The rotor is spun at a high speed inside the drum while material is fed right into a feed hopper. The material is impacted by the hammer bars and is thereby shredded and expelled through screens in the run of a selected size. Wood hammer mill is applied in wood pellets making industry and it is an important equipment in the complete production. Then what factors should you consider when choosing a wood hammer mill?
1. Choose the machine with easy operation, simple maintenance, reasonable price, and have better common ability.
2. To buy a suitable hammer mill (http://www.paradisedivingasia.com/eq...mmer-mill.html), you should consider the forestry enterprise production characteristic and production conditions.
3. To choose a suitable hammer mill, you should not only consider the economic aspects, but also consider manufacturing technology.
4. Choose high efficient hammer mill for work, because it can process much more material in the equal time, also can keep good quality on finished product.
5. Choose safety and reliable machine, as forestry enterprises operating condition is poorer than other companies, hard and durable machine is less likely to break.
Welcome to contact or visit Fote Machinery: [email protected].
