585,992 active members*
5,238 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > matsuura mc-800v yasnac mx3
    May 2015
    5
    hi everyone, i am going to buy a 1988 matsuura mc-800v with a yasnak MX3 controller. i have run it for test using powermill9 to generate toolpathes (offset area clearance,constant z finishing,raster finishing, helical drilling) and cimco software to link the machine an PC. my dnc settings was: stop bits 2,parity even,baud rate 9600,enable DTR checked,enable RTS checked,flow control software, X ON /17 XOF /19.
    I just tried the machine with offset roughing strategy and observed a really big problem with that.the machine couldnt move the smooth toolpathes with arcs and circles and ran the arc movements with something like 20-30 straight line moves.
    i really love and adore this machine and looking for a solution to solve the unsmooth circle movement problems of machine,.with at least 3000 mm/m cutting feed rate,while my strategy is real smoothed with fit arcs and corner radiuses.
    thanks for your helps...
    im using rs232 cable connection
    Feb 2009
    6028
    Re: matsuura mc-800v yasnac mx3
    100+ ipm feeds on interpolation with a 1988 MX3? Good luck with that. If it was an i80 maybe.....
  1. matsuura mc-800v
    By sardar_raveshi in forum CNC Machining Centers
    Last Post: 05-30-2015, 04:35 PM
  2. matsuura mc-800v
    By sardar_raveshi in forum Mori Seiki Mills
    Last Post: 05-30-2015, 04:29 PM
  3. matsuura mc-800v
    By sardar_raveshi in forum Post Processor Files
    Last Post: 05-30-2015, 04:26 PM
  4. matsuura mc-800v
    By sardar_raveshi in forum PowerMILL
    Last Post: 05-30-2015, 04:25 PM
  5. Matsuura 800v
    By AllenSilvey in forum Uncategorised MetalWorking Machines
    Last Post: 10-19-2014, 12:56 AM
