Homemade Vertical Mill Router by Aluminium Alloy Profile very easy and cheap
Parts and Tools:
4 or 6 or 8 SCS10UU 20 mm Linear Ball Bearing Motion Bearing CNC
2 x 300 mm 20 mm Linear Rails 2 x 400 mm 20 mm Linear Rails
2 pcs Aluminium Alloy Profile 400 mm x 80 mm
2 pcs Aluminium Alloy Profile 300 mm x 80 mm
Aluminium Alloy 6061 400 mm x 120 mm x 12 mm.
Aluminium Alloy 6061 400 mm x 800 mm x 12 mm.
Linear shaft 20 mm x 400 mm aixs
Linear shaft 20 mm x 300 mm aixs
Linear Rail Shaft Support XYZ Table 1 pcs 25mm
Linear Ball Bearing CNC
More Step by Step and More Homemade Lathe DIY Mill Miling CNC Router here:
