I have done a lot of research before recommending putting alignment laser for golf playing. It is just not an easy job to make proper recommendation of required laser line generator since it might be used both indoor and outdoor under the sunlight. As a result, beam visibility is very important concern during the selection of required alignment laser line. As a result, green alignment laser line is highly recommended to users.
Green laser line generator adopts 532nm green laser diode module as its laser line emission source. Its green laser beam is visible both daylight and at night. As a result, after users have made proper selection of required output power and lens degree, this laser alignment tool can make the most satisfied aiming of the ball for golf players. It is just working well in practical golf fields, and highly recommended by professors.
