585,987 active members*
4,623 visitors online*
    Jun 2015
    Hyundai HiT-8s
    I have a Hyundai Hit-8s Cnc Lathe. It has an error " 101 ORD1 prewarning replace battery". I was told to replace the battery with the machine on. Where is the battery and how do I do this? Does the dor have a power off switch when you open the power supply door?
    Jun 2004
    511
    Re: Hyundai HiT-8s
    What control? If it has a door switch there is usually a key to bypass it. Do leave the power on until you replace the battery, so you don't loose your memory. If it is an Fanuc there are two types. A black box that has D cells, or a special lithium cell on the controller itself.
    Jun 2015
    Re: Hyundai HiT-8s
    Hitrol-840C ez
    Jun 2004
    511
    Re: Hyundai HiT-8s
    I have no Siemens controllers in house at this time. The maintenance books should have a procedure, worst case check U tube.
  1. hyundai hit 8
    By drill in forum MetalWork Discussion
    Last Post: 09-10-2012, 01:17 AM
  2. hyundai 18s
    By protoman1 in forum Hyundai Kia
    Last Post: 02-07-2012, 11:48 PM
  3. Hyundai HIT 15S
    By lesarcs in forum Hyundai Kia
    Last Post: 12-28-2011, 10:44 PM
  4. Hyundai VMC
    By kevinkoons in forum Hyundai Kia
    Last Post: 03-30-2009, 06:27 PM
