SteelTailor Portable CNC cutting machine how to check START or FINISH Signal?
There are new questions with using portable cutting machine.
(Q)How to check START Signal and if the wire or connectors are okay?
(A)Attachment 282152
See if the cable is short even when CNC 2 cable is removed from the connector. If the cable is not showing shot when the CNC 2 cable is not connected to the CNC machine electrical box then do step 2.
(Q)How to check FINISH Signal and if the wire or connectors are okay?
(A)In the SteelTailor CNC cutting machine,Shot circuit finish 2 wires with a small wire.
Attachment 282154
Go to DIAGONOSE mode
When you shot circuit the 2 wires see if the state of the DLZ changes to 0 and when remove the short see if the state change back to 1
Attachment 282156
More information about SteelTailor FAQs, Pls visit:
Forum - Powered by Discuz!
Hope this is helpful to you .
Any other question ,pls email at [email protected].
You can also find us easily on facebook:SteelTailor Twitter:SteelTailor,
SteelTailor--The world leader of portable CNC cutting machine
www.steeltailor.com
