Hi
This is my first post here. I'm in Australia.
-5 C this moning, but +4 C in my workshop, so all good....
I have an SX3 mill wich works fine, although not long after got it I had to re-seat the speed display to get it to work properly - all OK now.
I have an isse with speed control. I used to be able to put the mill in "forward" or "reverse" then gently jog the quill rotation speed up and down using the up and down arrows.
Now I am havng problems - the only way I can get the speed to go up or down is hold in the up or down arrows untll you hear the normal "beeeeeeeeeeeep" and then the speed ramps up quickly, but to stop it at the desired speed I press the green start button, which then maintains the speed. The arrow buttons "click" but dont always work ever time.
Clearly this is a fault, any idea of best fix for it please?
I toyed with idea of ripping out buttons and putting in proper switches , but wasnt sure if it was a known fault or whether the issue lies with perhaps a cotroller board instead.
Apologies for posting in 2 spots, but this is driving me bonkers.
One thought that is going through my head is whether its worth replacing the speed controllers etc with 3rd party controllers.
Is it also woth having a mains surge protector on the machine?
Cheers
Steve
