585,931 active members*
5,616 visitors online*
    Oct 2006
    15
    Any Fanuc Karel people here?
    I'm trying to figure out how to send files throught the RS232 port of my Fanuc robot. I'm haing trouble with the OPEN and WRITE commands. Anyone here done any Karel programming?
    Mar 2007
    Quote Originally Posted by BobM3 View Post
    What controller?
    RF, RH,RJ..
    what software version?
    Sean
    Jul 2007
    Hello
    You may be able to adivice,,,, i also havea fanuc robot arm
    I have the task of modifying a welding (arc mate) robot in to a painting robot (my paint is water based so don’t worry). Anyway I am wondering for starters wich robot is better for my application the 100i or the 120i and with what controller, the gun that is going to be used will not weight more than 20 lb.
    Can some one please advice, I will really appreciate it, I also need information on how to choose the valves I will be using to work with the gun etc.
    Does anyone know if this has already been done somewhere?
    Thanks again!
    Mar 2007
    Quote Originally Posted by axbalin View Post
    Hello
    Thanks again!
    Paintshop robots spraying waterborne are still Class/Div rated for good reason.
    NOT advised.
    Sean
    Sep 2008
    100
    Hi I need the help for can programming a robot Fanuc S-420F with control RH the version Karel is 2.2... Idont know how program, Can I help me? mi email is [email protected]
