B and Z are not perpendicular. Do you have a procedure ? It is a FA 800 3 piece Curvic
thanks, Carl
thanks, Carl
B&Z? did you rotate B 180 and see if you get the same reading? If so, adjusting the B won't help. You either have a leveling problem on the machine, or something much worse going on.
