Hi
Please find log of my terminal
I have send new parameter to machine put same problem also i have new problem with ModBus inverter connection the machine cant see the inverter
Please i need parameter for 3000 router
uCito M2521 V2.11a C100
16M RAM installed.
Chan0: 180224, Chan1: 512
MCIF V4.46k, FPGA M22V223-GL-KN-LZ, KDM V4.46k (c) 2006 ETC.
Loading User INIT file.
Loading 8.05 MH-LDR Build 9
Loading 8.05 MH-STD Build 9 Location 2
Loading Teknic Module version 8.08 Location 6
Motion Buffer = 5000
Checking for exceptions
Checking for faults
Web Fault Check
All Web devices disabled
Enabling KDM
- SHORT ON KDM
Xa Home Xb Home Y Home Z Home {18}
> {6}A1{6}{13}
Enabling Motor Drives...HALT function active.
Drive 0 found: XA 3000 1 Status: 40200-CalOK--VectorRef-
Drive 1 found: Y 3000 1 Status: 40200-CalOK--VectorRef-
Drive 2 found: Z 3000 1 Status: 40200-CalOK--VectorRef-
Drive 4 found: XB 3000 1 Status: 40200-CalOK--VectorRef-
Motor Drives Enabled...
Version Information
**** MultiCam Inc. ****
** Router Machine S/N 3-204-R-PF05589 **
Loader V8.05.9
Standard V8.05
MCIF V4.46k
uCITO V2.11a
Keypad KDM20 V1.22
Controller :
M2521 Rev 3 Interface M22 (ID 8963)
Serial Num #12639
Speed 133MHz
Memory 16M
Clock 2258-247-255 223:255:223
Step Delay OFF
Baud/Parity 19200 Even
IP Address 192.168.0.17(255.255.255.0)
Web Voltage 22.287 VDC ( power is 24.1 VDC on power supply unit )
Thanks in advance
