585,996 active members*
4,222 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > how can i control spindle with A932A breakout board
    May 2015
    what is the port&pin number and what is the configuration in mach 3
    Jan 2009
    484
    Re: how can i control spindle with A932A breakout board
    I use that same board. I don't think it has any kind of spindle output, or if it does I wasn't able to figure out how to use it. There's a couple of options.... for cheap and dirty spindle control you could use a Vactrol, which works for ballpark RPM control but no power on/off and is the least "linear" so you will have to play with it some to get it tuned. ( http://www.cnczone.com/forums/open-s...ml#post1342790 )
    I went with the C41 from CNC4PC ( CNC4PC ) but I am using LinuxCNC, there could also be reasons to pick the C6 with Mach? I don't know. With moderate tweaking I was able to get within 100 RPM (Actually within about 30RPM, if I remember correctly) spindle control from it without having to add a spindle RPM feedback sensor or anything.
    I'm using the factory G0704 Motor control at the moment.
    Q: How many tools does it take before a simple task becomes a project?
    A: Just one. I'm the Tool that turns a simple task in to a project.
  1. Connecting a breakout board to spindle speed control
    By waisberg in forum Commercial CNC Wood Routers
    Last Post: 10-25-2012, 08:04 AM
  2. c11 breakout board spindle
    By dougputt in forum Machines running Mach Software
    Last Post: 08-07-2011, 04:13 AM
  3. breakout board with spindle speed control
    By 6bx in forum CNC Machine Related Electronics
    Last Post: 02-19-2009, 08:35 PM
  4. Need Breakout board to control Mach3
    By Mongkol in forum CNC Machine Related Electronics
    Last Post: 04-19-2008, 06:38 PM
  5. Router Speed Control + Mach3 + Breakout Board
    By Dingo745 in forum CNC Machine Related Electronics
    Last Post: 06-20-2007, 02:58 AM
