I recently got a great deal on a mini milling machine with a ton of goodies with it. The only minor issue that it does not have a base/X-Y table. Little machine Shop is backordered and I am waiting for a reply as to when they may have them back in stock. Would it be possible to get a flat steel plate such as 3/8" thick and then bolt the machine down to it with 123 blocks. Then bolt down a table such as this
http://cgi.ebay.com/COMPOUND-SLIDE-M...QQcmdZViewItem
or
http://cgi.ebay.com/6-HORIZ-VERT-ROT...QQcmdZViewItem
in front of it? Hopefully that makes sense to some of you folks that run mills. If not I can re-explain it. Thanks for any help you can offer. akraven
