585,959 active members*
4,867 visitors online*
Thread: Homemade
    Dec 2005
    132
    Homemade
    How hard would it be to convert a Tigwelder to a plasmacutter?.
    Jul 2005
    2415
    Wooo. Pretty hard I would think. About the only thing the two processes have in common is that they both use a constant current arc approach. TIG uses lower voltages and higher currents while plasma uses higher voltage (100 to 160VDC). There is the whole torch thingy with the air supply, arc start mechanism, etc.
    I would think it would be easier to change a Cessina 172 into a golf cart than the TIG to plasma conversion.
    Watch, as soon as I say this someone will post: "I took a TIG unit and rewound the transformer and did a few mods to the torch and it made a perfect plasma unit":bs:
    Dec 2005
    132
    Thought so, thanks anyway.
