585,967 active members*
4,505 visitors online*
    Jan 2013
    76
    A dual gantry machine
    Has anyone on here built a dual gantry CNC machine? I would like to build a multi-purpose CNC plasma, routing and drilling table. Just kicking around the idea of making two gantries. One for plasma cutting and the other for routing and drilling. The plasma gantry could be built much lighter to achieve the high acceleration/deceleration requirements. The routing drilling gantry could be built to withstand the rigors of drilling and routing. My plan is to use heavy ballscrews with driven nuts. Therefor the two gantries could co-exist on the same table utilizing the same linear rails and ballscrews. It would be a downdraft table.
    Just a thought. Is it a totally bad idea?
    Dec 2007
    9
    Re: A dual gantry machine
    Ballscrews may not provide you the high speed/acceleration you want for the plasma cutter. Maybe rack and pinion could be a better choice.
    I am planning to build a dual gantry CNC but mine would have two identical gantries so each one works on half of the material to halve machining time and using no more shop space (as two CNC would require otherwise).
    I am too interested on people's experiences about it. Control-wise I could wire it as two different CNCs that share one physical axis but that avoid having gantries colliding each other.
    Nov 2013
    33
    Quote Originally Posted by Black Forest View Post
    It is an good idea though I have not design a gantry cutting machine like this.Go ahead with your design. Good luck to you! If you need air plasma cutter, just feel free to contact me.
  1. [automated] Gantry alignment with dual ballscrew setup?
    By Ruso in forum DIY CNC Router Table Machines
    Last Post: 04-02-2015, 10:50 PM
  2. Dual motor gantry and Mach3 features that don't...
    By nova24 in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-12-2012, 10:03 PM
  3. Anyone updated an older single side drive gantry to dual?
    By panozeng in forum Waterjet General Topics
    Last Post: 01-09-2011, 05:50 AM
  4. Gantry with dual home switches
    By elogicca in forum LinuxCNC (formerly EMC2)
    Last Post: 12-18-2007, 04:15 AM
  5. Dual Drive Gantry Question?
    By Syphontek in forum Waterjet General Topics
    Last Post: 03-13-2006, 06:51 PM
